Introducción
When a laptop's battery becomes old and obsolete it may not be able to hold a charge and will need to be replaced. A new battery allows for a better power supply to important parts to the laptop for optimal usage. When removing the battery, it is important to be careful and use caution. You will need a #J0 Philips Screwdriver for the removal of the battery.
Use the #J0 screwdriver to unscrew the seven 4mm screws located around the back panel.
Using a JIS #0 screwdriver, unscrew the two 4mm screws securing the battery in place.
6 personas más completaron esta guía.
