Saltar al contenido principal
Dell Chromebook 11 CB1C13 Battery Replacement
Qué necesitas
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: paso 2, imagen 1 de 2 Dell Chromebook 11 CB1C13 Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: paso 3, imagen 1 de 2 Dell Chromebook 11 CB1C13 Battery Replacement: paso 3, imagen 2 de 2
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
Conclusión
To replace your Dell Chromebook 11 battery, follow these instructions in order.
2 personas más completaron esta guía.
Jerry Geffrard
Miembro Desde 03/25/15
334 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 1,411
