Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Qué necesitas
Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
Using the pull-tab, lift the hard-drive assembly out of the computer base.
Remove the screws that secure the hard drive(s) and slide the hard drive(s) out of the hard-drive bracket.
Place the NEW primary hard drive (HDD 0) in the hard-drive bracket.
If applicable, slide the secondary and tertiary hard drive(s) into the hard-drive bracket.
If applicable, replace the screws that secure the secondary hard drive (HDD 1) and tertiary hard drive (HDD 2) to the hard-drive bracket.
Connect the interposer to the hard drive(s).
Tighten the captive screws that secure the hard-drive assembly to the computer base.
Slide the hard-drive cable into the connector on the system board and press down on the connector latch to secure the cable.
