Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
Partes
No se requieren partes.
WARNING: Before working inside your computer, read the safety  information that shipped with your  computer and follow the steps in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  • Disconnect and peel off the video-card connector cable from the connectors on the system board.
Agregar Comentario
Pull the pull-tab to disconnect the display cable from the connector on the system board.
  • Pull the pull-tab to disconnect the display cable from the connector on the system board.
Agregar Comentario
  • Disconnect the LED-logo board cable from the connector on the system board.
Agregar Comentario
  • Close the display and turn the computer over.
  • Remove the screws that secure the display assembly on the computer base.
Agregar Comentario
  • Disconnect the antenna cables from the connectors on the Mini-Card.
  • Note the routing of the antenna cables, and then remove the cables from the routing guides on the computer base.
Agregar Comentario
  • Turn the computer over and open the display.
  • Note the routing of the display cable and LED-logo board cable, and then remove the cables from the routing guides on the palm-rest assembly.
Agregar Comentario
  • Remove the screws, on the display hinges, that secure the display assembly to the computer base.
Agregar Comentario
  • Gently slide out the antenna cables through the slot on the computer base.
Agregar Comentario
  • Move the display to a perpendicular position to the computer base, and then lift the display assembly off the computer.
Agregar Comentario
  • Place the NEW display assembly in position and replace the screws, on the display hinges, that secure the display assembly to the computer base.
Agregar Comentario
  • Route the display cable and LED-logo board cable through the routing guides on the palm-rest assembly.
Agregar Comentario
  • Connect the display cable, video-card connector cable, and LED-logo board cable to the respective connectors on the system board.
Agregar Comentario
  • Slide the Mini-Card antenna cables through the slot on the computer base.
Agregar Comentario
  • Route the Mini-Card antenna cables through the routing guides on the computer base.
Agregar Comentario
Conclusión
Terrence15
Miembro Desde 18/12/17
69,401 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
917 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 16
Todo El Tiempo: 108
