Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Memory Modules.
Partes
No se especificaron partes.
  1. Follow the instructions in Before You Begin. CAUTION:  To prevent damage to the memory -module connector, do not use tools to spread the memory module securing clips. Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
    • Follow the instructions in Before You Begin.
    • CAUTION: To prevent damage to the memory -module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Align the notch in the NEW memory module with the tab in the memory-module connector. Align the notch in the NEW memory module with the tab in the memory-module connector.
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Slide the memory module into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the  click, remove the memory module and reinstall it.
    • Slide the memory module into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 31
