Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Lift the connector latch that secures the hard-drive cable to the connector on the system board, and then disconnect the hard-drive cable from the connector on the system board.
  2. Loosen the four captive screws that secure the hard-drive assembly to the computer base.
    • Loosen the four captive screws that secure the hard-drive assembly to the computer base.
  3. Using the pull-tab, lift the hard-drive assembly out of the computer base.
    • Using the pull-tab, lift the hard-drive assembly out of the computer base.
  4. Disconnect the interposer from the hard drives.
    • Disconnect the interposer from the hard drives.
  5. Remove the four screws that secure the primary hard drive (HDD 0) and lift the hard drive out of the hard -drive bracket.
    • Remove the four screws that secure the primary hard drive (HDD 0) and lift the hard drive out of the hard -drive bracket.
  6. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  7. Remove the four screws that secure the secondary hard drive (HDD 1) and slide the hard drive out of the hard-drive bracket.
    • Remove the four screws that secure the secondary hard drive (HDD 1) and slide the hard drive out of the hard-drive bracket.
    • CAUTION: When the hard drive is not in the computer, store it in protective antistatic packaging (see "Protecting Against Electrostatic Discharge" in the safety instructions that shipped with your computer).
  8. Place the primary hard drive (HDD0) in the hard-drive bracket.
    • Place the primary hard drive (HDD0) in the hard-drive bracket.
  9. If applicable, slide the secondary hard drive into the hard-drive bracket.
    • If applicable, slide the secondary hard drive into the hard-drive bracket.
  10. Replace the four screws that secure the primary hard drive (HDD 0).
    • Replace the four screws that secure the primary hard drive (HDD 0).
  11. If applicable, replace the four screws that secure the secondary hard drive (HDD 1) to the hard-drive bracket.
    • If applicable, replace the four screws that secure the secondary hard drive (HDD 1) to the hard-drive bracket.
    • Connect the interposer to the hard drives.
  12. Place the hard-drive assembly in the computer base.
    • Place the hard-drive assembly in the computer base.
  13. Tighten the four captive screws that secure the hard-drive assembly to the computer base.
    • Tighten the four captive screws that secure the hard-drive assembly to the computer base.
  14. Connect the hard-drive cable to the connector on the system board and press down on the connector latch to secure the cable.
    • Connect the hard-drive cable to the connector on the system board and press down on the connector latch to secure the cable.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 8
Todo El Tiempo: 157
