Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Hard Drive.
Partes
No se especificaron partes.
  1. WARNING:  Before working inside your computer, read the safety information  that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Loosen the three captive screws that se cure the hard-drive assembly to the computer base.
  2. Using the pull-tab, lift the hard-drive assembly to disconnect it from the  connector on the system board.
    • Using the pull-tab, lift the hard-drive assembly to disconnect it from the connector on the system board.
  3. Lift the hard-drive assembly out of the computer base.
    • Lift the hard-drive assembly out of the computer base.
  4. Remove the four screws that secure the hard drive to the hard-drive  bracket.
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Lift the hard-drive off the hard-drive bracket.
    • Lift the hard-drive off the hard-drive bracket.
  7. Remove the interposer from the hard drive.
    • Remove the interposer from the hard drive.
  8. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  9. Place the hard drive in the hard-drive bracket. Place the hard drive in the hard-drive bracket.
    • Place the hard drive in the hard-drive bracket.
  10. Replace the four screws that secure the hard drive to the hard-drive  bracket.
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  11. Align the connector on the hard drive with the connector on the system  board and press the hard drive until it is fully seated.
    • Align the connector on the hard drive with the connector on the system board and press the hard drive until it is fully seated.
  12. Tighten the three captive screws that secure the hard-drive assembly to the  computer base.
    • Tighten the three captive screws that secure the hard-drive assembly to the computer base.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,815 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 2
Últimos 30 Días: 10
Todo El Tiempo: 166
