Introducción
In this guide, we will be showing you how to remove and replace the Memory Modules.
Partes
No se requieren partes.
  1. WARNING:   Before   working   inside   your   computer,   read   the   safety  information that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
    • Loosen the captive screw that secures the memory-module door to the computer base.
  2. Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
    • Slide the memory-module door to release the tabs and lift the memory- module door out of the computer base.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. CAUTION: If you need to remove memory modules from both connectors,  remove the memory module in the upper connector before you remove  the module in the lower connector. Use your fingertips to carefully spread apart the spring-locks on the memory  module connector until the module pops up. Use your fingertips to carefully spread apart the spring-locks on the memory  module connector until the module pops up.
    • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
    • Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
  5. Remove the memory module.
    • Remove the memory module.
  6. CAUTION:  If  you  need  to  install  memory  modules  in  two  connectors,  install  a  memory  module  in  the  lower  connector  before  you  install  a  module in the upper connector Align the notch on the NEW memory module with the tab on the memory module  connector.
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector
    • Align the notch on the NEW memory module with the tab on the memory module connector.
  7. Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the  click, remove the module and reinstall it. CAUTION:  If  the  memory  module  door  is  difficult  to  close,  remove  the  memory  module  and  reinstall  it.  Forcing  the  memory  module  door  to  close may damage your computer.
    • Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
    • CAUTION: If the memory module door is difficult to close, remove the memory module and reinstall it. Forcing the memory module door to close may damage your computer.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,583 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 85
