Introducción
In this guide, we will be showing you how to remove and replace the Memory Modules.
Partes
No se requieren partes.
WARNING:   Before   working   inside   your   computer,   read   the   safety  information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
  • Loosen the captive screw and slide the memory module door out of the computer base.
Agregar Comentario
CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove  the module in the lower connector.
  • CAUTION: If you need to remove memory modules from both connectors, remove the memory module in the upper connector before you remove the module in the lower connector.
  • Use your fingertips to carefully spread apart the spring-locks on the memory module connector until the module pops up.
Agregar Comentario
  • Remove the memory module.
Agregar Comentario
  • CAUTION: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a module in the upper connector.
  • Align the notch on the NEW memory module with the tab on the memory module connector.
Agregar Comentario
  • Insert the module into the memory module connector at a 45-degree angle, and press the module down until it clicks into place. If you do not hear the click, remove the module and reinstall it.
  • CAUTION: If the memory module door is difficult to close, remove the memory module and reinstall it. Forcing the memory module door to close may damage your computer.
  • NOTE: If the memory module is not installed properly, the computer may not boot.
Agregar Comentario
Conclusión
Terrence15
Miembro Desde 18/12/17
69,401 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
917 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 7
