Saltar al contenido principal
Dell Alienware M11x R3 Wi-Fi Card Replacement
Qué necesitas
  1. Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: paso 1, imagen 1 de 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: paso 1, imagen 2 de 3 Dell Alienware M11x R3 Wi-Fi Card Replacement, Lower Case: paso 1, imagen 3 de 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: paso 2, imagen 1 de 2 Dell Alienware M11x R3 Wi-Fi Card Replacement, Wi-Fi Card: paso 2, imagen 2 de 2
    • Your Wi-Fi card will have two coaxial cable wires connected to it.
    • Gently pull up the wires to disconnect them from the Wi-Fi card.
    • Be careful when you pull the wires. Pulling them hard or yanking them hard might cause damage to the wire or the Wi-Fi card.
  3. Dell Alienware M11x R3 Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Once the wires are removed, use an appropriate screwdriver to remove the screws holding down the Wi-Fi card.
  4. Dell Alienware M11x R3 Wi-Fi Card Replacement: paso 4, imagen 1 de 2 Dell Alienware M11x R3 Wi-Fi Card Replacement: paso 4, imagen 2 de 2
    • When the Wi-Fi card pop ups, slide it out of the socket.
    • Any mishandling of the Wi-Fi card will cause serious damage to it, so please be careful with it.
Conclusión
Richard Maurice
Miembro Desde 03/08/17
534 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 689
