Introducción
In this guide, we will show you how to remove and replace the Display Assembly.
WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Disconnect the antenna cables from the Mini-Card(s).
Agregar Comentario
Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
  • Note the routing of the Mini-Card antenna cables and remove them from the routing guides on the computer base.
Agregar Comentario
  • Turn the computer over and open the display as far as possible.
Agregar Comentario
  • Pull the pull-tab to disconnect the display cable from the connector on the system board.
Agregar Comentario
  • Remove the four screws that secure the display assembly to the computer base.
Agregar Comentario
  • Gently slide the Mini-Card antenna cables out through the slot on the computer base.
Agregar Comentario
  • Lift the display assembly off the computer.
Agregar Comentario
  • Slide the antenna cables in through the slot on the computer base.
Agregar Comentario
  • Place the NEW display assembly in position and replace the four screws that secure the display assembly to the computer base.
Agregar Comentario
  • Connect the display cable to the connector on the system board.
Agregar Comentario
  • Turn the computer over and route the Mini-Card antenna cables through the routing guides on the computer base.
Agregar Comentario
  • Connect the Mini-Card antenna cables to the Mini-Card(s).
Agregar Comentario
Conclusión
Terrence15
Miembro Desde 18/12/17
69,401 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
917 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 19
