Saltar al contenido principal
Dell Alienware M11x R3 2.5" Hard Drive Replacement
Qué necesitas
  1. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: paso 1, imagen 1 de 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: paso 1, imagen 2 de 3 Dell Alienware M11x R3  2.5" Hard Drive Replacement, Lower Case: paso 1, imagen 3 de 3
    • Loosen the eight retaining screws on the base of the computer with a small Phillips screwdriver.
    • The screws have retaining washers to hold them in place, so you don't have to remove them from the base plate.
    • Remove the bottom cover from the laptop.
  2. Dell Alienware M11x R3  2.5" Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • Remove the three screws attaching the hard drive tray to the laptop.
  3. Dell Alienware M11x R3  2.5" Hard Drive Replacement: paso 3, imagen 1 de 1
    • Grasp the plastic tab provided, and gently pull up. This will unplug the drive from the laptop.
  4. Dell Alienware M11x R3  2.5" Hard Drive Replacement: paso 4, imagen 1 de 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: paso 4, imagen 2 de 2
    • On both sides of the cage, there are two screws you have to unscrew to be able to remove the SSD.
  5. Dell Alienware M11x R3  2.5" Hard Drive Replacement: paso 5, imagen 1 de 2 Dell Alienware M11x R3  2.5" Hard Drive Replacement: paso 5, imagen 2 de 2
    • Finally, remove the L connector for the hard drive. You will need to put this on your new hard drive.
    • Make sure that the SSD you bought to replace this one has the same connections. I.e. able to connect to a SATA cord.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 1,566
