Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
In this guide, we will be showing you how to remove and replace the Memory Module.
Partes
No se especificaron partes.
  1. WARNING:   Before working inside your computer, read the safety information that shipped with your  computer and follow the steps in Before You Begin.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
  2. To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM3 and DIMM4, go to step 3.
    • To remove memory module(s) from connectors DIMM1 and DIMM2: Remove the palm rest. See"Removing the Palm Rest" on page 39.
  3. CAUTION:  To prevent damage to the memory-module connector, do  not use tools to spread the memory module securing clips.
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Using your fingertips, spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  4. Remove the memory module from the memory-module connector.
    • Remove the memory module from the memory-module connector.
  5. Align the notch on the NEW memory module with the tab on the memory-module connector.
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Slide the memory module firmly into the connector at a 45-degree angle and press  the memory module down until it clicks into place. If you do not hear the click,  remove the memory module and reinstall it.
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
Linea de Meta
2 personas más completaron esta guía.
darrius
Miembro Desde 26/03/18
5,102 Reputación
30 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
31 Miembros
1,842 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 134
