Saltar al contenido principal
Dell Alienware 15 R3 Speakers Replacement
Qué necesitas
  1. Dell Alienware 15 R3 Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Remove the 6 M2.5x13 that are holding the back cover on.
    • Remove the 1 M2x3 at the rear of the device that is holding the back cover on.
    • Gently pry on the sides of the back cover with the iFixit Opening Tool to release the tabs.
    • Remove the cover from the computer.
  2. Dell Alienware 15 R3 Speakers Replacement: paso 2, imagen 1 de 1
    • Disconnect the battery.
  3. Dell Alienware 15 R3 Speakers Replacement: paso 3, imagen 1 de 1
    • Remove the M2x3 screw holding the wireless card.
    • Lift and slide the wireless card from its slot.
  4. Dell Alienware 15 R3 Speakers Replacement: paso 4, imagen 1 de 3 Dell Alienware 15 R3 Speakers Replacement: paso 4, imagen 2 de 3 Dell Alienware 15 R3 Speakers Replacement: paso 4, imagen 3 de 3
    • Remove the two M2.5x6 screws connecting the rear cover to the computer.
    • Gently pry the rear cover with the iFixit Opening Tool to release the two tabs on each side.
    • Slide the rear cover from the computer.
  5. Dell Alienware 15 R3 Speakers Replacement: paso 5, imagen 1 de 3 Dell Alienware 15 R3 Speakers Replacement: paso 5, imagen 2 de 3 Dell Alienware 15 R3 Speakers Replacement: paso 5, imagen 3 de 3
    • Remove the light cable located between hard drive port and fan.
    • Open the latch and remove the keyboard cable, keyboard backlight cable, and the macro keys cable.
    • Remove the 11 M2.5x8 screws that secure the computer base.
    • Remove the 2 M2x3 screws.
    • Use a pry tool to separate the base from the computer and then lift the computer base from the computer.
  6. Dell Alienware 15 R3 Speakers Replacement: paso 6, imagen 1 de 2 Dell Alienware 15 R3 Speakers Replacement: paso 6, imagen 2 de 2
    • Remove the M2.5x5 screw holding the battery to the computer.
    • Remove the battery from the computer.
  7. Dell Alienware 15 R3 Speakers Replacement: paso 7, imagen 1 de 2 Dell Alienware 15 R3 Speakers Replacement: paso 7, imagen 2 de 2
    • Disconnect the speaker cable from the motherboard.
    • Lift the speakers from the computer.
Conclusión
Andrew M
Miembro Desde 03/28/23
433 Reputación
3 Guías creadas
Equipo
IUPUI, Team 2-4, Harley Spring 2023 Miembro de IUPUI, Team 2-4, Harley Spring 2023
IUPUI-HARLEY-S23S2G4
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 197
