Saltar al contenido principal
Dell Alienware 15 R3 SSD Replacement
Qué necesitas
  1. Dell Alienware 15 R3 SSD Replacement, Back Case: paso 1, imagen 1 de 3 Dell Alienware 15 R3 SSD Replacement, Back Case: paso 1, imagen 2 de 3 Dell Alienware 15 R3 SSD Replacement, Back Case: paso 1, imagen 3 de 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 SSD Replacement: paso 2, imagen 1 de 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 SSD Replacement, SSD: paso 3, imagen 1 de 1
    • Use the Phillips #00 to remove the 3.0 mm screws that secure the cover of the SSD.
    • Remove the cover from the SSD.
    • The cover is not pictured.
    • To prevent losing data, do NOT remove the SSD while the computer is on or in sleep mode.
    • Slide the old SSD card out of the slot.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 306
