Saltar al contenido principal
Dell Alienware 15 R3 Battery Replacement
Qué necesitas
  1. Dell Alienware 15 R3 Battery Replacement, Back Case: paso 1, imagen 1 de 3 Dell Alienware 15 R3 Battery Replacement, Back Case: paso 1, imagen 2 de 3 Dell Alienware 15 R3 Battery Replacement, Back Case: paso 1, imagen 3 de 3
    • Before you begin, turn off the laptop and unplug the charger.
    • Flip the laptop over so that the backside is facing up.
    • Use a Phillips #00 screwdriver to remove the six 13.0 mm screws from the sides of the back case.
    • Use a Phillips #00 screwdriver to remove one 5.0 mm screw from the back of the laptop.
  2. Dell Alienware 15 R3 Battery Replacement: paso 2, imagen 1 de 1
    • Use the opening tool to pry the back case from the computer.
    • Use the opening tool and work your way around the perimeter of the back case to gently release the clips.
    • Start from the black vent for an easier removal.
    • Lift the back case off of the laptop.
  3. Dell Alienware 15 R3 Battery Replacement, Cover Assembly: paso 3, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove two screws from the side of the laptop.
  4. Dell Alienware 15 R3 Battery Replacement: paso 4, imagen 1 de 2 Dell Alienware 15 R3 Battery Replacement: paso 4, imagen 2 de 2
    • Use an opening tool to release the four tabs from the hinge cover and gently pry it off.
  5. Dell Alienware 15 R3 Battery Replacement: paso 5, imagen 1 de 3 Dell Alienware 15 R3 Battery Replacement: paso 5, imagen 2 de 3 Dell Alienware 15 R3 Battery Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove nine screws from the chassis.
    • Use a spudger or opening tool to remove the chassis and reveal the battery, fan, motherboard, and other components.
  6. Dell Alienware 15 R3 Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 5.0 mm screw that is securing the battery to the palm rest assembly.
  7. Dell Alienware 15 R3 Battery Replacement: paso 7, imagen 1 de 3 Dell Alienware 15 R3 Battery Replacement: paso 7, imagen 2 de 3 Dell Alienware 15 R3 Battery Replacement: paso 7, imagen 3 de 3
    • To the upper right of the battery is a connecting cable. Gently disconnect it from the palm rest assembly.
    • Confirm nothing else is connected to the battery and lift the battery completely off the palm rest assembly.
Conclusión
2 personas más completaron esta guía.
Un comentario
does not seem to be for my alienware r3 15 inch
Craig Anderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 10
Ultimos 7 días: 59
Ultimos 30 días: 269
Todo El Tiempo: 5,624
