Introducción
In this guide, we will show you how to remove and replace the Battery.
Herramientas
No se requieren herramientas.
Partes
No se requieren partes.
WARNING: Before working inside your computer, read the  safety information that shipped with your computer and  follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions  in  After Working Inside Your Computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
  • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
  • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
  • Remove the screw that secures the solid-state drive to the computer base.
Agregar Comentario
Slide and remove the solid-state drive from the solid-state drive slot.
  • Slide and remove the solid-state drive from the solid-state drive slot.
Agregar Comentario
  • Slide the NEW solid-state drive into the solid-state drive slot.
Agregar Comentario
  • Align the screw hole on the solid-state drive with the screw hole on the computer base.
Agregar Comentario
  • Replace the screw that secures the solid-state drive to the computer base.
Agregar Comentario
Agregar Comentario
  • Note the front AlienFX LED cable routing and peel off the cable from the battery.
Agregar Comentario
  • Remove the screws that secure the battery to the computer base.
Agregar Comentario
  • Lift the battery off the computer base.
Agregar Comentario
  • Align the screw holes on the NEW battery with the screw holes on the computer base.
Agregar Comentario
  • Adhere the front AlienFX LED cable to the battery.
Agregar Comentario
  • Route the speaker cable through the routing guides on the battery.
Agregar Comentario
  • Replace the screws that secure the battery to the computer base.
Agregar Comentario
Conclusión
Terrence15
Miembro Desde 18/12/17
69,401 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
917 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 98
