Saltar al contenido principal
Introducción
In this guide, we will show you how to remove and replace the Power-Button Board.
Herramientas
No se especificaron herramientas.
Partes
No se especificaron partes.
  1. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin. . After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display, and turn the computer over.
  2. Remove the screws that secure the base cover to the computer base. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Slide and lift the base cover off the computer base.
    • Slide and lift the base cover off the computer base.
  4. Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
    • Align the tabs on the NEW base cover with the slots on the computer base and slide the base cover into place.
  5. Replace the screws that secure the base cover to the computer base.
    • Replace the screws that secure the base cover to the computer base.
  6. Turn the computer over and open the display.
    • Turn the computer over and open the display.
  7. WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.   After working inside your computer, follow the instructions in After Working Inside Your Computer.
  8. Remove the screws that secure the battery to the computer base.
    • Remove the screws that secure the battery to the computer base.
  9. Using the battery cable, lift the battery and release it from the tabs on the computer base.
    • Using the battery cable, lift the battery and release it from the tabs on the computer base.
  10. Turn the computer over and open the display as far as possible.
    • Turn the computer over and open the display as far as possible.
  11. Press and hold the power button for five seconds to ground the system board.
    • Press and hold the power button for five seconds to ground the system board.
    • Close the display and turn the computer over.
  12. Align the tabs on the NEW battery with  the slots on the computer base.
    • Align the tabs on the NEW battery with the slots on the computer base.
  13. Align the screw holes on the battery with  the screw holes on the computer base.
    • Align the screw holes on the battery with the screw holes on the computer base.
  14. Replace the screws that secure the battery to the computer base.
    • Replace the screws that secure the battery to the computer base.
  15. Connect the battery cable to the system-board connector.
    • Connect the battery cable to the system-board connector.
  16. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer,  follow the instructions in After Working Inside Your Computer. CAUTION:  To avoid data loss, do not remove the hard drive while the  computer is On or in Sleep state.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is On or in Sleep state.
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • NOTE: The secondary hard-drive or solid-state drive is optional and can be installed in the optical drive bay.
    • Remove the screws that secure the secondary hard-drive assembly to the computer base.
  17. Carefully lift the secondary hard-drive assembly and then lift the latches to release  the secondary hard-drive cable from the system-board connector. Carefully lift the secondary hard-drive assembly and then lift the latches to release  the secondary hard-drive cable from the system-board connector. Carefully lift the secondary hard-drive assembly and then lift the latches to release  the secondary hard-drive cable from the system-board connector.
    • Carefully lift the secondary hard-drive assembly and then lift the latches to release the secondary hard-drive cable from the system-board connector.
  18. Lift the secondary hard-drive assembly off the computer base.
    • Lift the secondary hard-drive assembly off the computer base.
  19. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  20. Turn the secondary hard-drive assembly over.
    • Turn the secondary hard-drive assembly over.
  21. Remove the screw that secures the secondary hard-drive assembly to the main  bracket.
    • Remove the screw that secures the secondary hard-drive assembly to the main bracket.
  22. Remove the screws that secure the secondary hard-drive to the secondary  hard-drive bracket.
    • Remove the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  23. Slide and lift the secondary hard-drive  off the secondary hard-drive bracket. Slide and lift the secondary hard-drive  off the secondary hard-drive bracket.
    • Slide and lift the secondary hard-drive off the secondary hard-drive bracket.
  24. Disconnect the interposer from the secondary hard-drive connector. Disconnect the interposer from the secondary hard-drive connector.
    • Disconnect the interposer from the secondary hard-drive connector.
  25. Connect the interposer to the secondary hard-drive connector.
    • Connect the interposer to the secondary hard-drive connector.
  26. Place the NEW secondary hard-drive in  the secondary hard-drive bracket.
    • Place the NEW secondary hard-drive in the secondary hard-drive bracket.
  27. Align the screw holes on the secondary hard-drive with the screw holes on the  secondary hard-drive bracket.
    • Align the screw holes on the secondary hard-drive with the screw holes on the secondary hard-drive bracket.
  28. Replace the screws that secure the secondary hard-drive to the secondary hard-drive  bracket.
    • Replace the screws that secure the secondary hard-drive to the secondary hard-drive bracket.
  29. Align the screw hole on the secondary hard-drive assembly with the screw hole on  the main bracket.
    • Align the screw hole on the secondary hard-drive assembly with the screw hole on the main bracket.
  30. Replace the screw that secures the secondary hard-drive assembly to the main  bracket.
    • Replace the screw that secures the secondary hard-drive assembly to the main bracket.
  31. Turn the secondary hard-drive assembly over.
  32. Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
    • Slide the secondary hard-drive cable into the system-board connector and press down on the connector latches to secure the cable.
  33. Align the screw holes on the secondary hard-drive assembly with the screw holes on  the computer base.
    • Align the screw holes on the secondary hard-drive assembly with the screw holes on the computer base.
    • Replace the screws that secure the secondary hard-drive assembly to the computer base.
  34. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer,  follow the instructions in After Working Inside Your Computer. Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
    • Lift the connector latch and pull the pull-tab to disconnect the status-light board cable from the system-board connector and slide the cable into the slot on the computer base.
  35. Remove the screws that secure the palm -rest assembly to the computer base.
    • Remove the screws that secure the palm -rest assembly to the computer base.
  36. Turn the computer over and open  the display as far as possible.
  37. Using a plastic scribe, pry the palm-rest assembly from the computer base. Using a plastic scribe, pry the palm-rest assembly from the computer base.
    • Using a plastic scribe, pry the palm-rest assembly from the computer base.
  38. Carefully lift the palm-rest assembly and turn it over.
    • Carefully lift the palm-rest assembly and turn it over.
  39. Release the connector latches to disconnect the flexi-cable from the system board. Release the connector latches to disconnect the flexi-cable from the system board.
    • Release the connector latches to disconnect the flexi-cable from the system board.
    • Connect the flexi-cable to the connector on the system board.
  40. Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Turn the NEW palm-rest assembly over and slide the status-light board cable through the slot on the computer base.
    • Align the palm-rest assembly over the computer base and snap the palm-rest assembly into place.
  41. Close the display and turn the computer over.
  42. Replace the screws that secure the palm-rest assembly to the computer base.
    • Replace the screws that secure the palm-rest assembly to the computer base.
  43. Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
    • Slide the status-light board cable into the system-board connector and press on the connector latch to secure the cable.
  44. WARNING: Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer,  follow the instructions in After Working Inside Your Computer. Lift the connector latch and disconnect  the power-button board cable from the  connector on the status-light board. Lift the connector latch and disconnect  the power-button board cable from the  connector on the status-light board.
    • Lift the connector latch and disconnect the power-button board cable from the connector on the status-light board.
  45. Make a note of the power-button board cable routing and peel off the power-button board cable from the keyboard bracket. Make a note of the power-button board cable routing and peel off the power-button board cable from the keyboard bracket.
    • Make a note of the power-button board cable routing and peel off the power-button board cable from the keyboard bracket.
  46. Remove the screws that secure the power-button board to the palm-rest assembly.
    • Remove the screws that secure the power-button board to the palm-rest assembly.
  47. Lift the power-button board along with its cable off the palm-rest assembly.
    • Lift the power-button board along with its cable off the palm-rest assembly.
  48. Align the screw holes on the NEW power-button board with the screw holes on the palm-rest assembly.
    • Align the screw holes on the NEW power-button board with the screw holes on the palm-rest assembly.
  49. Replace the screws that secure the power-button board to the palm-rest assembly.
    • Replace the screws that secure the power-button board to the palm-rest assembly.
  50. Route the power-button board cable on the keyboard bracket and adhere the cable to the keyboard bracket.
    • Route the power-button board cable on the keyboard bracket and adhere the cable to the keyboard bracket.
  51. Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable. Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable.
    • Slide the power-button board cable into the status-light board connector and press down on the connector latch to secure the cable.
Conclusión
Terrence15
Miembro Desde 18/12/17
70,785 Reputación
442 Guías creadas
Equipo
Informative Technologies Inc. Miembro de Informative Technologies Inc.
Community
15 Miembros
925 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 29
