Introducción
This guide will show the user how to replace a heat-sink assembly with a damaged or broken fan on a Dell Alienware 13 laptop.
Qué necesitas
Herramienta utilizada en este paso:Heavy-Duty Spudger$4.99
Remove the small access panel using a heavy duty spudger.
Disconnect the antenna cables from the wireless card using a heavy duty spudger. The wires can be removed by applying a force directed upward, away from the device.
Disconnect (2) fan cables attaching the fans to the motherboard.
2 personas más completaron esta guía.
