Saltar al contenido principal
Dell AC511 Rear Panel Replacement
Qué necesitas
  1. Dell AC511 Rear Panel Replacement, Front Panel: paso 1, imagen 1 de 3 Dell AC511 Rear Panel Replacement, Front Panel: paso 1, imagen 2 de 3 Dell AC511 Rear Panel Replacement, Front Panel: paso 1, imagen 3 de 3
    • Use a Jimmy to peel off the screen stuck to the front of the speaker.
    • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
    • Be careful to avoid damage to the rest of the speaker and especially to yourself.
    • Don't worry if it tears; use the Jimmy again to peel off the rest.
  2. Dell AC511 Rear Panel Replacement: paso 2, imagen 1 de 2 Dell AC511 Rear Panel Replacement: paso 2, imagen 2 de 2
    • Remove ten 6 mm screws using a Phillips #1 screwdriver.
  3. Dell AC511 Rear Panel Replacement: paso 3, imagen 1 de 2 Dell AC511 Rear Panel Replacement: paso 3, imagen 2 de 2
    • Lift the front panel off of the rest of the device.
    • The speakers will still be attached to the front panel. Being too rough could damage them.
    • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
    • Remove the front panel from the device.
  4. Dell AC511 Rear Panel Replacement, Speaker: paso 4, imagen 1 de 2 Dell AC511 Rear Panel Replacement, Speaker: paso 4, imagen 2 de 2
    • Follow the three wires connected to the speaker to find where they connect to the circuit board.
    • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
  5. Dell AC511 Rear Panel Replacement, Volume Knob: paso 5, imagen 1 de 1
    • Apply a light downward pressure on the circuit board next to the volume control.
    • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
  6. Dell AC511 Rear Panel Replacement: paso 6, imagen 1 de 1
    • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
    • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
  7. Dell AC511 Rear Panel Replacement, Rear Panel: paso 7, imagen 1 de 1
    • Use the pointy end of the spudger to push the audio jack ports into the device to disconnect the secondary circuit board from the rear ranel.
    • Do not use too much force. Pushing too hard will risk breaking the audio jacks.
  8. Dell AC511 Rear Panel Replacement: paso 8, imagen 1 de 2 Dell AC511 Rear Panel Replacement: paso 8, imagen 2 de 2
    • Remove the 10 mm bolt using a socket wrench with a 10-11 mm socket.
    • After removing the bolt, pull the disconnected volume control board out.
Conclusión
William Cook
Miembro Desde 03/19/24
617 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 99
