Saltar al contenido principal
Dell 1908FPc Monitor USB Hard drive Replacement
Qué necesitas
  1. Dell 1908FPc Monitor USB Hard drive Replacement, USB Motherboard: paso 1, imagen 1 de 3 Dell 1908FPc Monitor USB Hard drive Replacement, USB Motherboard: paso 1, imagen 2 de 3 Dell 1908FPc Monitor USB Hard drive Replacement, USB Motherboard: paso 1, imagen 3 de 3
    • Pop the front bezel off by inserting fingers underneath the left or right inside edge of screen.
    • Do not try to remove the bezel completely as there is a ribbon cable attached to the bottom for the buttons located in the bottom right hand corner.
    • A lot of pressure is required to remove the bezel. Do not be afraid of asserting some force.
  2. Dell 1908FPc Monitor USB Hard drive Replacement: paso 2, imagen 1 de 2 Dell 1908FPc Monitor USB Hard drive Replacement: paso 2, imagen 2 de 2
    • Turn the monitor over. Unscrew the four 4mm x 10mm screws on the back of the monitor and remove the plastic backing.
  3. Dell 1908FPc Monitor USB Hard drive Replacement: paso 3, imagen 1 de 2 Dell 1908FPc Monitor USB Hard drive Replacement: paso 3, imagen 2 de 2
    • Unscrew the 3mm x 4mm screw that retains the side USB shield.
    • Remove shield and set aside.
  4. Dell 1908FPc Monitor USB Hard drive Replacement: paso 4, imagen 1 de 3 Dell 1908FPc Monitor USB Hard drive Replacement: paso 4, imagen 2 de 3 Dell 1908FPc Monitor USB Hard drive Replacement: paso 4, imagen 3 de 3
    • Remove the five 3mm x 2mm screws that retain the metal cover protecting the electronics.
    • Remove the four 2.75mm x 6.75mm studs by the video imput ports.
    • Slide the cover downwards to unlock and remove cover.
  5. Dell 1908FPc Monitor USB Hard drive Replacement: paso 5, imagen 1 de 2 Dell 1908FPc Monitor USB Hard drive Replacement: paso 5, imagen 2 de 2
    • Unplug board connections.
    • Uncsrew the four 3mm x 5.5mm screws that hold the USB motherboard down.
    • Get new board ready to install.
Conclusión
You now know how to replace the USB motherboard on a Dell 1908FPc monitor.
Una persona más ha completado esta guía.
Connor Henshaw
Miembro Desde 10/02/17
128 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 556
