Saltar al contenido principal
Dell Inspiron 15-7569 Motherboard Replacement
Qué necesitas
  1. Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 3 Dell   Inspiron  15-7569 Motherboard Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the (10) P58F black screws on the back cover using the Phillips #0 screwdriver.
    • After removing the screws, remove the back cover using a plastic or metal spudger.
  2. Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: paso 2, imagen 1 de 3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: paso 2, imagen 2 de 3 Dell   Inspiron  15-7569 Motherboard Replacement, Motherboard: paso 2, imagen 3 de 3
    • Unscrew the (6) six black screws outlined using a Phillips #0 screwdriver.
    • Unscrew (4) screws securing the fan using a Phillips #0 head screwdriver.
    • Remove the fan from the motherboard.
  3. Dell   Inspiron  15-7569 Motherboard Replacement: paso 3, imagen 1 de 3 Dell   Inspiron  15-7569 Motherboard Replacement: paso 3, imagen 2 de 3 Dell   Inspiron  15-7569 Motherboard Replacement: paso 3, imagen 3 de 3
    • Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires.
    • Remove the black speaker wire.
    • Remove the white display wire.
  4. Dell   Inspiron  15-7569 Motherboard Replacement: paso 4, imagen 1 de 3 Dell   Inspiron  15-7569 Motherboard Replacement: paso 4, imagen 2 de 3 Dell   Inspiron  15-7569 Motherboard Replacement: paso 4, imagen 3 de 3
    • (Continued)Unplug all wires from motherboard, including battery wire, speaker wire, screen wire, and other component wires
    • Remove the gold and silver display cables.
    • Remove the white fan cable.
    • Remove the USB-to-motherboard cable
  5. Dell   Inspiron  15-7569 Motherboard Replacement: paso 5, imagen 1 de 2 Dell   Inspiron  15-7569 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the black battery cable.
    • Remove the blue ribbon cable.
    • Unscrew and remove hard drive/SSD.
    • Disconnect the hard drive/SSD from the motherboard.
  6. Dell   Inspiron  15-7569 Motherboard Replacement: paso 6, imagen 1 de 2 Dell   Inspiron  15-7569 Motherboard Replacement: paso 6, imagen 2 de 2
    • Gently remove the motherboard from the device.
Conclusión
Equipo
USF Tampa, Team S5-G4, Walkup Fall 2017 Miembro de USF Tampa, Team S5-G4, Walkup Fall 2017
USFT-WALKUP-F17S5G4
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 1,545
