Saltar al contenido principal
Decorative Light Fixture Lightbulb Replacement
Qué necesitas
  1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: paso 1, imagen 1 de 1
    • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    • Position a sturdy ladder beneath the light fixture.
  2. Decorative Light Fixture Lightbulb Replacement: paso 2, imagen 1 de 2 Decorative Light Fixture Lightbulb Replacement: paso 2, imagen 2 de 2
    • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
    • If possible, have someone else hold the fixture for you.
    • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
  3. Decorative Light Fixture Lightbulb Replacement: paso 3, imagen 1 de 1
    • Place the fixture and any loose screws off to the side.
  4. Decorative Light Fixture Lightbulb Replacement: paso 4, imagen 1 de 2 Decorative Light Fixture Lightbulb Replacement: paso 4, imagen 2 de 2
    • Unscrew the lightbulb from the fixture.
  5. Decorative Light Fixture Lightbulb Replacement: paso 5, imagen 1 de 1
    • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
  6. Decorative Light Fixture Lightbulb Replacement: paso 6, imagen 1 de 2 Decorative Light Fixture Lightbulb Replacement: paso 6, imagen 2 de 2
    • Re-screw the lightbulb into the fixture.
  7. Decorative Light Fixture Lightbulb Replacement: paso 7, imagen 1 de 2 Decorative Light Fixture Lightbulb Replacement: paso 7, imagen 2 de 2
    • Hold onto the fixture, and screw it back in with the screwdriver.
Linea de Meta
Jordan Parry
Miembro Desde 03/30/21
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 27
Todo El Tiempo: 299
