Saltar al contenido principal
DeWalt DWE4011 Power Cable Replacement
Qué necesitas
  1. DeWalt DWE4011 Power Cable Replacement, Power Cord: paso 1, imagen 1 de 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
  2. DeWalt DWE4011 Power Cable Replacement: paso 2, imagen 1 de 2 DeWalt DWE4011 Power Cable Replacement: paso 2, imagen 2 de 2
    • Remove bottom casing by separating the end handle away from the main casing.
  3. DeWalt DWE4011 Power Cable Replacement: paso 3, imagen 1 de 2 DeWalt DWE4011 Power Cable Replacement: paso 3, imagen 2 de 2
    • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
  4. DeWalt DWE4011 Power Cable Replacement: paso 4, imagen 1 de 1
    • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
  5. DeWalt DWE4011 Power Cable Replacement: paso 5, imagen 1 de 2 DeWalt DWE4011 Power Cable Replacement: paso 5, imagen 2 de 2
    • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
  6. DeWalt DWE4011 Power Cable Replacement: paso 6, imagen 1 de 2 DeWalt DWE4011 Power Cable Replacement: paso 6, imagen 2 de 2
    • Locate the terminals with the two white cables attached and disconnect both.
    • These cables are connected to the outer terminals; connect as such during reassembly.
  7. DeWalt DWE4011 Power Cable Replacement: paso 7, imagen 1 de 2 DeWalt DWE4011 Power Cable Replacement: paso 7, imagen 2 de 2
    • Remove the entirety of the cable housing from the device casing.
    • The two wires coming from the power cable should still be connected to electrical housing at this point.
  8. DeWalt DWE4011 Power Cable Replacement: paso 8, imagen 1 de 1
    • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
    • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
Conclusión
4 personas más completaron esta guía.
Un comentario
Where can I find a replacement power cord?
Ethan Sligar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 12
Ultimos 30 días: 49
Todo El Tiempo: 3,355
