Saltar al contenido principal
DeWalt DWE4011 Carbon Brushes Replacement
Qué necesitas
  1. DeWalt DWE4011 Carbon Brushes Replacement, Carbon Brushes: paso 1, imagen 1 de 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Carbon Brushes Replacement: paso 2, imagen 1 de 1
    • Remove the outer casing to expose the brushes by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Carbon Brushes Replacement: paso 3, imagen 1 de 2 DeWalt DWE4011 Carbon Brushes Replacement: paso 3, imagen 2 de 2
    • Locate both carbon brushes on either side of the device.
  4. DeWalt DWE4011 Carbon Brushes Replacement: paso 4, imagen 1 de 1
    • Using the iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Carbon Brushes Replacement: paso 5, imagen 1 de 1
    • Keeping a tight hold the entire time, move the spring covering the carbon brush so that it is behind the male terminal.
    • Be extremely careful, as the spring is tightly coiled and can easily get away from you.
  6. DeWalt DWE4011 Carbon Brushes Replacement: paso 6, imagen 1 de 2 DeWalt DWE4011 Carbon Brushes Replacement: paso 6, imagen 2 de 2
    • Taking hold of the wire you removed in step 4, gently slide the carbon brush out of its casing and remove it from the device.
    • Flip over the device to reveal the second carbon brush, and repeat steps 4 through 6 on the other side.
Conclusión
Congratulations! To put your device back together, simply reverse the above steps.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 32
Todo El Tiempo: 1,366
