Saltar al contenido principal
DeWalt DWE4011 Brush Spring Replacement
Qué necesitas
  1. DeWalt DWE4011 Brush Spring Replacement, Brush Spring: paso 1, imagen 1 de 1
    • Turn to the bottom of the device and remove the 5/8" (17mm) screw shown using a T15 Torx Screwdriver.
  2. DeWalt DWE4011 Brush Spring Replacement: paso 2, imagen 1 de 1
    • Remove outer casing by pulling the end handle away from the field case.
  3. DeWalt DWE4011 Brush Spring Replacement: paso 3, imagen 1 de 1
    • Locate the brush springs on either side of the device.
  4. DeWalt DWE4011 Brush Spring Replacement: paso 4, imagen 1 de 1
    • Using an iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
  5. DeWalt DWE4011 Brush Spring Replacement: paso 5, imagen 1 de 1
    • Remove the spring by sliding it out of the center post (use an iFixit opening tool if needed).
    • When replacing the spring you need to tension it. Watch this video at 1:55 to see how.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 1,159
