Saltar al contenido principal
DeWalt DWD112 Brush Replacement
Qué necesitas
  1. DeWalt DWD112 Brush Replacement, Power Cord: paso 1, imagen 1 de 1
    • Remove seven TR20 Torx Security screws from the side of the drill.
  2. DeWalt DWD112 Brush Replacement: paso 2, imagen 1 de 1
    • Remove the top cover to reveal the inside of the drill.
    • Set the top cover of the drill aside.
  3. DeWalt DWD112 Brush Replacement: paso 3, imagen 1 de 1
    • The power cord and the trigger act as a single part and must be replaced together.
    • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
  4. DeWalt DWD112 Brush Replacement: paso 4, imagen 1 de 1
    • Disconnect the second connected wire from the top of the trigger box.
  5. DeWalt DWD112 Brush Replacement: paso 5, imagen 1 de 1
    • Lift the trigger box up to reveal the bottom side.
    • Disconnect the first connected wire from the bottom of the trigger box.
  6. DeWalt DWD112 Brush Replacement: paso 6, imagen 1 de 1
    • Disconnect the last wire from the trigger box using the same method from the previous step.
  7. DeWalt DWD112 Brush Replacement: paso 7, imagen 1 de 1
    • After all four wires are disconnected, the trigger and power cord are separated from the drill.
    • The power cord and trigger can be set aside if further disassembly is required.
  8. DeWalt DWD112 Brush Replacement, Armature: paso 8, imagen 1 de 1
    • Take note of the keyless chuck and the meshing of the gears.
  9. DeWalt DWD112 Brush Replacement: paso 9, imagen 1 de 2 DeWalt DWD112 Brush Replacement: paso 9, imagen 2 de 2
    • Grab the metal chuck by the rotating spindle as if you are to tighten in a drill bit.
    • Lift the metal chuck out of its resting place and set aside.
  10. DeWalt DWD112 Brush Replacement: paso 10, imagen 1 de 3 DeWalt DWD112 Brush Replacement: paso 10, imagen 2 de 3 DeWalt DWD112 Brush Replacement: paso 10, imagen 3 de 3
    • With your left hand, grab hold of the field, which is the large metal block with coils looped around the inside.
    • Use your other hand to take the bearing out from the end of the gear connected to the armature.
  11. DeWalt DWD112 Brush Replacement: paso 11, imagen 1 de 3 DeWalt DWD112 Brush Replacement: paso 11, imagen 2 de 3 DeWalt DWD112 Brush Replacement: paso 11, imagen 3 de 3
    • Lift the field up once more with one hand and grab the cooling fan with the other hand and gently slide the armature out of the field.
    • The brushes will now be disconnected from the armature, meaning no current can flow from the power cord to the motor.
  12. DeWalt DWD112 Brush Replacement, Field: paso 12, imagen 1 de 3 DeWalt DWD112 Brush Replacement, Field: paso 12, imagen 2 de 3 DeWalt DWD112 Brush Replacement, Field: paso 12, imagen 3 de 3
    • Move the black wire clear from any obstruction.
    • Repeat this step for the white wire and the red wire.
  13. DeWalt DWD112 Brush Replacement: paso 13, imagen 1 de 2 DeWalt DWD112 Brush Replacement: paso 13, imagen 2 de 2
    • The field is disconnected from all other parts.
    • Grab the field and gently lift it out of the case.
  14. DeWalt DWD112 Brush Replacement, Brush: paso 14, imagen 1 de 2 DeWalt DWD112 Brush Replacement, Brush: paso 14, imagen 2 de 2
    • Using two fingers, press the brush into the metal casing.
    • Firmly pull out the brush using the same two fingers.
  15. DeWalt DWD112 Brush Replacement: paso 15, imagen 1 de 2 DeWalt DWD112 Brush Replacement: paso 15, imagen 2 de 2
    • Repeat the same process to remove the second brush.
Conclusión
Joe Echelmeier
Miembro Desde 03/09/16
298 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 888
