Saltar al contenido principal
DeWalt DW997 Motor Replacement
Qué necesitas
  1. DeWalt DW997 Motor Replacement, Speed Switch: paso 1, imagen 1 de 2 DeWalt DW997 Motor Replacement, Speed Switch: paso 1, imagen 2 de 2
    • Remove seven 21 mm Torx T15 screws.
    • Remove one 18 mm Torx T10 screw.
    • After removing all screws, lift up the top yellow cover.
    • The yellow cover should easily lift up, if not, check for unscrewed screws.
    • Do not pry the two yellow covers apart, they can crack.
  2. DeWalt DW997 Motor Replacement: paso 2, imagen 1 de 1
    • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
  3. DeWalt DW997 Motor Replacement: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
  4. DeWalt DW997 Motor Replacement: paso 4, imagen 1 de 1
    • Remove the other leg manually, it should easily come out.
  5. DeWalt DW997 Motor Replacement, Motor: paso 5, imagen 1 de 2 DeWalt DW997 Motor Replacement, Motor: paso 5, imagen 2 de 2
    • Use a Torx T10 screw bit to remove the four 11mm screws around the motor.
  6. DeWalt DW997 Motor Replacement: paso 6, imagen 1 de 2 DeWalt DW997 Motor Replacement: paso 6, imagen 2 de 2
    • Pull off the two wires that connect the motor to the trigger.
    • Be careful while pulling the wires as they can tear.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 2,253
