Saltar al contenido principal
DeWalt DW997 Forward/Reverse Switch Replacement
Qué necesitas
  1. DeWalt DW997 Forward/Reverse Switch  Replacement, Forward/Reverse Switch: paso 1, imagen 1 de 1
    • There should be 7 screws that are 21 mm long, remove them with a TorxT15 bit.
    • There should be 1 screw that is 18 mm long, remove it with a Torx T10 bit.
    • Note: Keep all 8 screws together to avoid losing them .
  2. DeWalt DW997 Forward/Reverse Switch  Replacement: paso 2, imagen 1 de 2 DeWalt DW997 Forward/Reverse Switch  Replacement: paso 2, imagen 2 de 2
    • Once all screws are removed, remove the plastic siding by slowly prying open the two sides all the way around.
    • Caution: Do not pry the two pieces apart with a tool. Once all the screws are out, the two parts should split.
  3. DeWalt DW997 Forward/Reverse Switch  Replacement: paso 3, imagen 1 de 3 DeWalt DW997 Forward/Reverse Switch  Replacement: paso 3, imagen 2 de 3 DeWalt DW997 Forward/Reverse Switch  Replacement: paso 3, imagen 3 de 3
    • Locate the forward/reverse switch above the trigger. Lift up the copper colored trigger assembly and lift up the switch with two fingers.
    • Note: The switch should easily come out.
  4. DeWalt DW997 Forward/Reverse Switch  Replacement: paso 4, imagen 1 de 2 DeWalt DW997 Forward/Reverse Switch  Replacement: paso 4, imagen 2 de 2
    • Take the replacement switch and place it in the trigger assembly that the faulty switch was removed from. The new switch has two legs on one side, the bigger triangular shaped leg should be towards the front of the drill.
    • Note: The side of the switch that has the two legs is placed facing down.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 33
Todo El Tiempo: 3,814
