Saltar al contenido principal
DeWalt DW920 Trigger Replacement
Qué necesitas
  1. DeWalt DW920 Trigger Replacement, Disassembly: paso 1, imagen 1 de 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Trigger Replacement: paso 2, imagen 1 de 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Trigger Replacement: paso 3, imagen 1 de 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Trigger Replacement, Trigger: paso 4, imagen 1 de 1
    • Gently lift the broken trigger assembly out of the slot.
  5. DeWalt DW920 Trigger Replacement: paso 5, imagen 1 de 1
    • Use a soldering iron to desolder the points where the trigger assembly is attached to the motor assembly.
    • The soldering iron is very hot and will burn. Use with caution.
Conclusión
Stephen Rada
Miembro Desde 03/11/16
433 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 513
