Saltar al contenido principal
DeWalt DW920 Motor Replacement
Qué necesitas
  1. DeWalt DW920 Motor Replacement, Disassembly: paso 1, imagen 1 de 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Motor Replacement: paso 2, imagen 1 de 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Motor Replacement: paso 3, imagen 1 de 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Motor Replacement, Motor: paso 4, imagen 1 de 1
    • Gently lift the motor and trigger mechanism out from the frame of the drill.
  5. DeWalt DW920 Motor Replacement: paso 5, imagen 1 de 1
    • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
    • Mark where the two cables was connected using a masking tape or similar.
  6. DeWalt DW920 Motor Replacement: paso 6, imagen 1 de 1
    • Solder the new motor assembly wires to the trigger mechanism in the same fashion that the old motor was.
    • Remember to check the markers from the step before and solder the cables on the right place.
Conclusión
Stephen Rada
Miembro Desde 03/11/16
433 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 12
Todo El Tiempo: 806
