Saltar al contenido principal
DeWalt DW920 Lock Switch Replacement
Qué necesitas
  1. DeWalt DW920 Lock Switch Replacement, Disassembly: paso 1, imagen 1 de 1
    • Using an H-5.0 bit driver remove the four T-10 Torx screws.
  2. DeWalt DW920 Lock Switch Replacement: paso 2, imagen 1 de 1
    • Use 2 H-5.0 bit drivers to take out the main bolt and head.
    • There will be blue locktite on the tread.
  3. DeWalt DW920 Lock Switch Replacement: paso 3, imagen 1 de 1
    • Carefully remove the two halves of the handle.
  4. DeWalt DW920 Lock Switch Replacement, Lock Switch: paso 4, imagen 1 de 1
    • Locate the switch on the top of the drill right before the bending joint.
  5. DeWalt DW920 Lock Switch Replacement: paso 5, imagen 1 de 2 DeWalt DW920 Lock Switch Replacement: paso 5, imagen 2 de 2
    • Firmly grasp the switch with two fingers and lift it straight up. The spring should remain attached to the switch during this process.
    • It should lift right out. If it is caught on anything do not force it out.
Conclusión
Stephen Rada
Miembro Desde 03/11/16
433 Reputación
4 Guías creadas
Equipo
Un comentario
This guide was descriptive and easy to follow. Good job!
DankMemerino - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 260
