Saltar al contenido principal
DeWalt DW660 Motor Brushes Replacement
Qué necesitas
  1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: paso 1, imagen 1 de 2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: paso 1, imagen 2 de 2
    • Remove the four 19mm T20 Torx screws at the rear of the device.
  2. DeWalt DW660 Motor Brushes Replacement: paso 2, imagen 1 de 3 DeWalt DW660 Motor Brushes Replacement: paso 2, imagen 2 de 3 DeWalt DW660 Motor Brushes Replacement: paso 2, imagen 3 de 3
    • Remove the other part of the back casing.
    • Unplug the black and white power wires from the motor.
  3. DeWalt DW660 Motor Brushes Replacement: paso 3, imagen 1 de 2 DeWalt DW660 Motor Brushes Replacement: paso 3, imagen 2 de 2
    • Pinch the blue brush wire between two fingers.
    • Pull on the wire, removing them from the motor.
  4. DeWalt DW660 Motor Brushes Replacement: paso 4, imagen 1 de 2 DeWalt DW660 Motor Brushes Replacement: paso 4, imagen 2 de 2
    • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
    • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
  5. DeWalt DW660 Motor Brushes Replacement: paso 5, imagen 1 de 2 DeWalt DW660 Motor Brushes Replacement: paso 5, imagen 2 de 2
    • Repeat steps 3 and 4 to remove the other carbon brush.
    • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
    • Refer to the photos for visual assistance.
Conclusión
Una persona más ha completado esta guía.
Joseph Pacitto
Miembro Desde 03/23/16
239 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,429
