Saltar al contenido principal
DeWalt DC970 Motor Replacement
Qué necesitas
  1. DeWalt DC970 Motor Replacement, Battery: paso 1, imagen 1 de 1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Motor Replacement: paso 2, imagen 1 de 1
    • Remove battery from drill.
  3. DeWalt DC970 Motor Replacement, Drill Assembly: paso 3, imagen 1 de 2 DeWalt DC970 Motor Replacement, Drill Assembly: paso 3, imagen 2 de 2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Motor Replacement: paso 4, imagen 1 de 1
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Motor Replacement, Motor: paso 5, imagen 1 de 1
    • Lift drill mechanism out of the shell.
    • Desolder the red and black wires from the motor.
    • Learn more about soldering here.
  6. DeWalt DC970 Motor Replacement: paso 6, imagen 1 de 1
    • Slightly twist and pull motor away from the clutch.
  7. DeWalt DC970 Motor Replacement: paso 7, imagen 1 de 1
    • When installing the replacement motor into the clutch make sure you correctly align the gears in order to assure that the motor is properly fitted to the clutch.
Conclusión
2 personas más completaron esta guía.
Equipo
3 comentarios
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
allen.anderson1 - Contestar
Thanks for the heads up on the wires
Daniel Randall - Contestar
Is there a fix to replace brushes?
pmac086 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 43
Todo El Tiempo: 6,609
