Saltar al contenido principal
DeWalt DC970 Forward/Reverse switch Replacement
Qué necesitas
  1. DeWalt DC970 Forward/Reverse switch Replacement, Battery: paso 1, imagen 1 de 1
    • Compress the buttons on either side of the battery and lift the drill away from battery.
  2. DeWalt DC970 Forward/Reverse switch Replacement: paso 2, imagen 1 de 1
    • Remove battery from drill.
  3. DeWalt DC970 Forward/Reverse switch Replacement, Drill Assembly: paso 3, imagen 1 de 2 DeWalt DC970 Forward/Reverse switch Replacement, Drill Assembly: paso 3, imagen 2 de 2
    • Remove the eight 16 mm, Torx Security #15 screws.
  4. DeWalt DC970 Forward/Reverse switch Replacement: paso 4, imagen 1 de 1
    • Lay the drill on its side and gently lift the top half off it.
  5. DeWalt DC970 Forward/Reverse switch Replacement, Forward/Reverse switch: paso 5, imagen 1 de 1
    • Remove the drill mechanism from the shell.
  6. DeWalt DC970 Forward/Reverse switch Replacement: paso 6, imagen 1 de 2 DeWalt DC970 Forward/Reverse switch Replacement: paso 6, imagen 2 de 2
    • Disconnect the forward/reverse switch from the trigger by pulling the mechanism out and leaving the switch in the frame.
    • To replace just pull the switch out and put the new one in the opening.
Conclusión
jake
Miembro Desde 03/10/16
303 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 2,516
