Saltar al contenido principal
DeWalt D28110 Power Switch Replacement
Qué necesitas
  1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: paso 1, imagen 1 de 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
    • Unplug the grinder before any disassembly.
  2. DeWalt D28110 Power Switch Replacement: paso 2, imagen 1 de 2 DeWalt D28110 Power Switch Replacement: paso 2, imagen 2 de 2
    • Pull out the gear case.
  3. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: paso 3, imagen 1 de 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  4. DeWalt D28110 Power Switch Replacement: paso 4, imagen 1 de 1
    • Use the edge of the spudger to loosen and remove the back panel.
  5. DeWalt D28110 Power Switch Replacement: paso 5, imagen 1 de 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
  6. DeWalt D28110 Power Switch Replacement: paso 6, imagen 1 de 1
    • Pull back the rear side of the back panel.
  7. DeWalt D28110 Power Switch Replacement, Power Switch: paso 7, imagen 1 de 3 DeWalt D28110 Power Switch Replacement, Power Switch: paso 7, imagen 2 de 3 DeWalt D28110 Power Switch Replacement, Power Switch: paso 7, imagen 3 de 3
    • There is an inner plastic guard behind the motor shaft.
    • Unscrew the four screws at each corner.
    • The guard should pull out with a good firm tug.
  8. DeWalt D28110 Power Switch Replacement: paso 8, imagen 1 de 3 DeWalt D28110 Power Switch Replacement: paso 8, imagen 2 de 3 DeWalt D28110 Power Switch Replacement: paso 8, imagen 3 de 3
    • Just behind the inner guard is the button slide.
    • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
  9. DeWalt D28110 Power Switch Replacement: paso 9, imagen 1 de 3 DeWalt D28110 Power Switch Replacement: paso 9, imagen 2 de 3 DeWalt D28110 Power Switch Replacement: paso 9, imagen 3 de 3
    • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
  10. DeWalt D28110 Power Switch Replacement: paso 10, imagen 1 de 2 DeWalt D28110 Power Switch Replacement: paso 10, imagen 2 de 2
    • Disconnect the motor wires from the other side of the switch box.
    • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
Conclusión
3 personas más completaron esta guía.
Kean Wee
Miembro Desde 01/22/15
495 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 18-6, Maness Winter 2015 Miembro de Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Miembros
7 Guías creadas
Un comentario
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 38
Todo El Tiempo: 5,627
