Saltar al contenido principal
DeWalt D26451 Power Switch Replacement
Qué necesitas
  1. DeWalt D26451 Power Switch Replacement, Power Cord: paso 1, imagen 1 de 1
    • Please wear safety glasses while completing this guide.
    • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
  2. DeWalt D26451 Power Switch Replacement: paso 2, imagen 1 de 1
    • Gently pry the cap off using your fingers or spudger tool.
  3. DeWalt D26451 Power Switch Replacement: paso 3, imagen 1 de 1
    • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
  4. DeWalt D26451 Power Switch Replacement: paso 4, imagen 1 de 1
    • Loosen the white and black wire terminals
  5. DeWalt D26451 Power Switch Replacement: paso 5, imagen 1 de 1
    • Insert new power cord terminals and tighten down
    • Do not over-tighten
  6. DeWalt D26451 Power Switch Replacement, Power Switch: paso 6, imagen 1 de 1
    • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
  7. DeWalt D26451 Power Switch Replacement: paso 7, imagen 1 de 1
  8. DeWalt D26451 Power Switch Replacement: paso 8, imagen 1 de 1
    • Once the cap is removed, the switch and connectors should be exposed
  9. DeWalt D26451 Power Switch Replacement: paso 9, imagen 1 de 1
    • Remove both connectors from the switch
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 1,329
