Saltar al contenido principal
DeWALT Hammer Drill DW511 Power Cord Replacement
Qué necesitas
  1. DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: paso 1, imagen 1 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: paso 1, imagen 2 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove three 19 mm T20 Torx screws from the back of the drill.
  2. DeWALT Hammer Drill DW511 Power Cord Replacement: paso 2, imagen 1 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement: paso 2, imagen 2 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement: paso 2, imagen 3 de 3
    • Place an opening tool in the groove line of the handle and pop the back loose.
    • Grab the drill with two hands and pull the cover off.
  3. DeWALT Hammer Drill DW511 Power Cord Replacement, Power Cord: paso 3, imagen 1 de 2 DeWALT Hammer Drill DW511 Power Cord Replacement, Power Cord: paso 3, imagen 2 de 2
    • Firmly grab the body of the trigger.
    • Slowly pull the trigger until the entire body is out and only attached by wires.
  4. DeWALT Hammer Drill DW511 Power Cord Replacement: paso 4, imagen 1 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement: paso 4, imagen 2 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • With sharp point tweezers, push the little metal flap up in the hole holding the wire.
    • Clamp the wire with blunt tweezers, and slowly pull the wire out.
  5. DeWALT Hammer Drill DW511 Power Cord Replacement: paso 5, imagen 1 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement: paso 5, imagen 2 de 3 DeWALT Hammer Drill DW511 Power Cord Replacement: paso 5, imagen 3 de 3
    • With a pair of blunt nose tweezers, grab the white wire.
    • Carefully wiggle the wire loose.
    • Pull the wire slowly until it comes out.
  6. DeWALT Hammer Drill DW511 Power Cord Replacement: paso 6, imagen 1 de 1
    • With both wires free, the power cord is free from the trigger body.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 30
Todo El Tiempo: 1,442
