Saltar al contenido principal
De' Longhi CTOV 2103- AZ
Qué necesitas
  1. De' Longhi CTOV 2103- AZ, Pull the lever: paso 1, imagen 1 de 3 De' Longhi CTOV 2103- AZ, Pull the lever: paso 1, imagen 2 de 3 De' Longhi CTOV 2103- AZ, Pull the lever: paso 1, imagen 3 de 3
    • First unplug the cable. ...Pull off the lever, it is snapped in.
    • Pull out the drawer.
    • Now clean it with a vacuum.
    • On the underside are 4 screws Torx 10 resistant visible - in each corner one.
  2. De' Longhi CTOV 2103- AZ, Screw: paso 2, imagen 1 de 2 De' Longhi CTOV 2103- AZ, Screw: paso 2, imagen 2 de 2
    • Detail of the screw
  3. De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: paso 3, imagen 1 de 3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: paso 3, imagen 2 de 3 De' Longhi CTOV 2103- AZ, Housing chrome plastic ring: paso 3, imagen 3 de 3
    • here you have two pictures of the housing and the chrome plastic frame.
  4. De' Longhi CTOV 2103- AZ, Lever: paso 4, imagen 1 de 2 De' Longhi CTOV 2103- AZ, Lever: paso 4, imagen 2 de 2
    • Here you have details of the lever and how it is snapped in the mechanic.
    • This shows you how to unlock it when you dismantle the housing. Good luck. ;)
  5. De' Longhi CTOV 2103- AZ, Tempeaturesensor: paso 5, imagen 1 de 2 De' Longhi CTOV 2103- AZ, Tempeaturesensor: paso 5, imagen 2 de 2
    • Detail of the Sensor: It is the little black pearl at the black hoses which is strapped to the white hose.
  6. De' Longhi CTOV 2103- AZ: paso 6, imagen 1 de 3 De' Longhi CTOV 2103- AZ: paso 6, imagen 2 de 3 De' Longhi CTOV 2103- AZ: paso 6, imagen 3 de 3
    • The connector from the main platine to the switch platine.
  7. De' Longhi CTOV 2103- AZ: paso 7, imagen 1 de 3 De' Longhi CTOV 2103- AZ: paso 7, imagen 2 de 3 De' Longhi CTOV 2103- AZ: paso 7, imagen 3 de 3
    • Details of the plug and the bottom part after disassembly.
    • Where to find the plug for the yellow ground wire i show you in the next step. :)
  8. De' Longhi CTOV 2103- AZ: paso 8, imagen 1 de 2 De' Longhi CTOV 2103- AZ: paso 8, imagen 2 de 2
    • here you can see where the yellow cable belongs to.
  9. De' Longhi CTOV 2103- AZ, Reassembly: paso 9, imagen 1 de 3 De' Longhi CTOV 2103- AZ, Reassembly: paso 9, imagen 2 de 3 De' Longhi CTOV 2103- AZ, Reassembly: paso 9, imagen 3 de 3
    • Reassembly: Putt all cables at the right places, don't forget the yellow cable at the housing !!!
    • Look at the picture how to fit in the metal notch in the right place !
  10. De' Longhi CTOV 2103- AZ: paso 10, imagen 1 de 3 De' Longhi CTOV 2103- AZ: paso 10, imagen 2 de 3 De' Longhi CTOV 2103- AZ: paso 10, imagen 3 de 3
    • Here the notch is in the right place.
    • Do NOT forget to make an insulation test. Check the wiring with a multimeter.
    • Made in China.
    • Hope it was fun and may the pictures help you. Greets. :)
Conclusión
2 personas más completaron esta guía.
Schwarzstein
Miembro Desde 07/15/13
2,813 Reputación
13 Guías creadas
2 comentarios
The lever broke on my toaster. And it's difficult to glue it.
skan - Contestar
My daughter toasted a piece of bread but the bread burned and caught fire. I've opened the toaster, and see no fire-damage. Although, it is impossible to toast because the lever won't stay down.
Dieter Troubleyn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 32
Todo El Tiempo: 2,436
