Introducción
This guide will go step-by-step in how to replace the fuel injector lines for a 1977 Datsun 280z. When these fuel lines rot or break, fuel can leak into the engine compartment, causing the engine to not function properly and can lead to the car to catch on fire. The fuel injector lines are important in maintaining this classic car. Hopefully with this guide, it will be easy and painless to replace these fuel injector lines and get the Datsun 280z up and running properly.
Qué necesitas
Release the hood latch by pulling the knob within the cab towards you.
Reach to the middle of the hood and pull the lever upward to release the hook.
Extend the hood upward to view the engine.
Una persona más ha completado esta guía.
Un comentario
Good instructions including visual. Question, I have a 1980 280 ZX on which I had to have the fuel tank rebuilt. When replacing it I removed all the old hoses, fuel pressure regulator, and relief valve. I should have made better notes or taken pictures. I am uncertain where the relief valve goes as I'm reassembling. I am purchasing a new adjustable fuel pressure regulator valve which will be relocated in the engine compartment. Any thoughts would be appreciated. Thank you.
Gary
