Saltar al contenido principal
Dashcam DOD LS300W Battery Replacement
Qué necesitas
  1. Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: paso 1, imagen 1 de 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: paso 1, imagen 2 de 3 Dashcam DOD LS300W Battery Replacement, This is the dashcam DOD LS300W: paso 1, imagen 3 de 3
    • Using an opening tool, pry open the seam on the bottom of the dash cam to separate the two parts of the device.
  2. Dashcam DOD LS300W Battery Replacement: paso 2, imagen 1 de 2 Dashcam DOD LS300W Battery Replacement: paso 2, imagen 2 de 2
    • Notice the connection of + and - on the top left side of the inside of the dash cam. Make note of this as it will be important to remember when you solder on the new battery.
    • Desolder the old battery. This is a 250mAh.
  3. Dashcam DOD LS300W Battery Replacement: paso 3, imagen 1 de 3 Dashcam DOD LS300W Battery Replacement: paso 3, imagen 2 de 3 Dashcam DOD LS300W Battery Replacement: paso 3, imagen 3 de 3
    • The new battery is 400mAh. and fits just in the battery location.
    • Solder in the new battery.
    • Then place the new battery into the space previously occupied by the old battery.
    • See the difference between old and new battery.
    • Be careful to solder the positive side of the new battery into the same spot that the old battery was soldered into.
  4. Dashcam DOD LS300W Battery Replacement: paso 4, imagen 1 de 1
    • Put the dashcam back together.
    • Charge the battery to the full level, and you are ready to go.
Conclusión
Once again, thank you for checking out this guide and I hope it helped!
2 personas más completaron esta guía.
Pierre
Miembro Desde 04/02/13
542 Reputación
3 Guías creadas
2 comentarios
Hi mate, where did you buy the replacement battery from? I'm having trouble finding something online? blackdogwood@bigpond.com
Cheers,
Russell Edwards - Contestar
Hi Russell, I found this battery on Ebay.
Good luck.
Cheers.
Pierre - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 64
Todo El Tiempo: 6,175
