Saltar al contenido principal
Dare To Repair: How To Create a Guide
  1. Dare To Repair: How To Create a Guide, Dare To Repair: How To Create a Guide: paso 1, imagen 1 de 2 Dare To Repair: How To Create a Guide, Dare To Repair: How To Create a Guide: paso 1, imagen 2 de 2
    • First things first—you'll need to create an account. Go to iFixit.com, then click Join on the top-right corner of the homepage. Next, fill in the boxes with your information and click that big blue Create My Account button to finish.
    • So far, so good! Now that you have an account, you’re ready to start creating content on the site.
  2. Dare To Repair: How To Create a Guide, Guide Photos: paso 2, imagen 1 de 2 Dare To Repair: How To Create a Guide, Guide Photos: paso 2, imagen 2 de 2
    • Behind every great repair guide, there are quality photos. Don't worry—you don't need a professional camera to take good photos. We put together a few guides with some photography tips and tricks to help get you started:
    • How to Take Awesome Photos
    • How to Take Awesome Photos with Your Smartphone
    • Now that you're primed to be the next Ansel Adams, you can start documenting your repair process. Take a photo for every step of your repair process. We'll show you how and where to upload them in a bit.
  3. Dare To Repair: How To Create a Guide: paso 3, imagen 1 de 3 Dare To Repair: How To Create a Guide: paso 3, imagen 2 de 3 Dare To Repair: How To Create a Guide: paso 3, imagen 3 de 3
    • Your beautiful pictures need a guide to live in! Before you getcha' guide on, check to see if your device already exists on the iFixit site by searching for your device on the iFixit homepage.
    • If your device exists, click Create a Guide located to the right of the device photo.
    • Didn't find your device? No problem. Just click Create a Guide from the Guide Homepage.
  4. Dare To Repair: How To Create a Guide: paso 4, imagen 1 de 1
    • Now, select what type of guide you will be writing.
    • For the Dare to Repair contest, select Replacement.
    • Then, fill out the section “What part are you replacing ?”
  5. Dare To Repair: How To Create a Guide: paso 5, imagen 1 de 1
    • Next up, fill out the Search Summary. Fun fact—this summary isn't visible on our site, but it tells search engines how to find your guide. So make sure it includes the name of the device and describes what your guide accomplishes in one sentence. The better the summary, the more likely you'll be discovered and become repair-famous.
    • Click Show More to get started on your Guide Introduction.
  6. Dare To Repair: How To Create a Guide: paso 6, imagen 1 de 1
    • Your Introduction should outline what your guide covers, and why someone would need it. Introductions appear at the top of the guide.
    • We'd also like you to include a brief explanation that tells us why you chose to model your replacement part.
    • Under Flags, select Dare to Repair from the drop down list.
    • This is very important! We won't be able to find your submission without this flag. Which means we won't be able to give you $$ if we can't find your guide.
    • Save your work by clicking that big blue Save button on the bottom right of your screen.
  7. Dare To Repair: How To Create a Guide, Upload your model: paso 7, imagen 1 de 1
    • At the top of your screen, you'll see three tabs. Click the Details tab to add information about your modeling procedure. Then upload the raw files. Here's a list of the file types we accept:
    • (.3ds) (.amf) (.blend) (.c4d) (.dwg) (.fbx) (.ma) (.obj) (.stl)
    • Click Add New to attach any documents you want us to see.
    • Hit Save.
  8. Dare To Repair: How To Create a Guide: paso 8, imagen 1 de 1
    • Now sharpen your keyboard and get ready to write. In the text box to the right of the empty picture box, write the instructions for the first step of your repair.
    • Once you're happy with your text, it’s time for images!
    • To add a new step, select the white plus sign in the yellow box at the top right of your screen. Then add text to your new step. Rinse and repeat for every step in your guide.
  9. Dare To Repair: How To Create a Guide: paso 9, imagen 1 de 2 Dare To Repair: How To Create a Guide: paso 9, imagen 2 de 2
    • Time to add all those pretty pictures you took. Click the camera icon in the photo box to open the Media Manager.
    • Once you're in the Media Manager, upload photo files from your computer by selecting Add Media.
    • Once your photo has uploaded, click on it to place it on the guide step.
    • To rearrange the order of the photos, click and drag the photo to move it to the desired position on the image shelf.
  10. Dare To Repair: How To Create a Guide: paso 10, imagen 1 de 2 Dare To Repair: How To Create a Guide: paso 10, imagen 2 de 2
    • Photo editing tools can be found by clicking Edit, located at the bottom right corner of the image.
    • If you’d like to highlight something specific in your image—like the location of small screws or connectors—select Markup.
    • Pro Tip: You can change the color of the corresponding bullet by clicking on it. Color coding your bullets to match the pictures in a step makes it easier for readers to follow along. Plus, colors are fun.
    • You know what else is fun? Adding Caution, Note, and Reminder bullets to your guides. The easier it is to follow your guide, the more people will use it. The more people that use it, the more devices we save from the landfill. So basically, we're relying on you to help us save the world. No pressure, tho.
    • And PLEASE Don't forget to save your work! The world needs to see your guide.
  11. Dare To Repair: How To Create a Guide: paso 11, imagen 1 de 1
    • If you're not happy with your guide (or you're a crazy perfectionist), you can always go back and edit. Just select Edit on the top right corner of the guide to re-open your work.
    • That's it! That’s everything you need to know to create a guide. Feel free to comment below with any questions. Thanks for contributing and happy fixing!
Conclusión
Thank you for your contribution!
Una persona más ha completado esta guía.
Documentos Adjuntos
Kelsea Weber
Miembro Desde 11/12/15
19,023 Reputación
32 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
138 Miembros
16,982 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 33
Todo El Tiempo: 1,238
