Saltar al contenido principal
Dangle Earrings Jump Ring Replacement
Qué necesitas
  1. Dangle Earrings Jump Ring Replacement, Jump Ring: paso 1, imagen 1 de 1
    • Locate where the earring stud/hook has detached.
    • Look at the two pieces of the dangle earrings for a small loop or jump ring on both pieces.
  2. Dangle Earrings Jump Ring Replacement: paso 2, imagen 1 de 1
    • Using a chain nose plier, carefully grip the jump ring by its side.
    • Use a cutting plier to cut a small opening in the loop.
  3. Dangle Earrings Jump Ring Replacement: paso 3, imagen 1 de 1
    • With both pliers use the cutting plier to gently grip the side of the small jump ring.
    • Using the small nose chain pliers pull back on the small jump ring to create an opening.
  4. Dangle Earrings Jump Ring Replacement: paso 4, imagen 1 de 1
    • With the small chain nose pliers grip the jump ring.
    • Insert the stud/hook portion of the earring into the jump ring.
  5. Dangle Earrings Jump Ring Replacement: paso 5, imagen 1 de 1
    • Use the jump ring to reattach the the stud.
    • Insert the main portion of the earring into the jump ring with the stud/hoop.
  6. Dangle Earrings Jump Ring Replacement: paso 6, imagen 1 de 1
    • Use both pliers to close the loop.
    • Firmly grip the edge of the loop using a pair of cutting pliers.
    • With a pair of small chain grip pliers gently push the end of the jump ring forward to close the loop.
  7. Dangle Earrings Jump Ring Replacement: paso 7, imagen 1 de 1
    • Gently tug on either side of the earring to ensure the loop is closed securely.
    • If this test fails, refer back to step 6.
Conclusión
Angelika Dela Torre
Miembro Desde 01/16/22
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 37
Todo El Tiempo: 327
