Saltar al contenido principal
DYMO LabelWriter 450 Eject Button Replacement
Qué necesitas
  1. DYMO LabelWriter 450 Eject Button Replacement, Back Plate: paso 1, imagen 1 de 3 DYMO LabelWriter 450 Eject Button Replacement, Back Plate: paso 1, imagen 2 de 3 DYMO LabelWriter 450 Eject Button Replacement, Back Plate: paso 1, imagen 3 de 3
    • Make sure the device is unplugged. Then, turn over the device so that the label is readable.
    • Remove the two 15.7mm screws on the top of the device first, and then the two 26.5mm screws on the bottom (they are in the smaller holes and larger holes respectively) using a Phillips #1 screwdriver.
    • You need a spudger to orient the bottom screws so that they can be removed.
  2. DYMO LabelWriter 450 Eject Button Replacement: paso 2, imagen 1 de 2 DYMO LabelWriter 450 Eject Button Replacement: paso 2, imagen 2 de 2
    • Once the Back Plate has been unscrewed, you will see the components from the top of the device plugged into the motherboard. You will only have 1-2 inches of clearance to unplug the components from the motherboard.
    • There are four components to unplug: the power cable connector, the two small no-fuss ribbon cable connectors, and the large no-fuss ribbon cable connector. The order does not matter.
    • This device has a blade located within the front panel. When handling the device, be careful not to touch the blade.
  3. DYMO LabelWriter 450 Eject Button Replacement, Eject Button: paso 3, imagen 1 de 1
    • Turn the device upright and lift the lid. Carefully pull off the side panel that has the eject button on it until the panel gives way.
Conclusión
Una persona más ha completado esta guía.
Jared Finkel
Miembro Desde 10/09/18
649 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G4, Leahy Fall 2018 Miembro de USF Tampa, Team S1-G4, Leahy Fall 2018
USFT-LEAHY-F18S1G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 2,395
