Saltar al contenido principal
DYMO LabelPOINT 100 Battery Replacement
Qué necesitas
  1. DYMO LabelPOINT 100 Battery Replacement, Removing Battery Cover: paso 1, imagen 1 de 2 DYMO LabelPOINT 100 Battery Replacement, Removing Battery Cover: paso 1, imagen 2 de 2
    • Slide the battery cover release button.
    • Remove battery cover.
  2. DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: paso 2, imagen 1 de 3 DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: paso 2, imagen 2 de 3 DYMO LabelPOINT 100 Battery Replacement, Removing Batteries: paso 2, imagen 3 de 3
    • Remove all six Triple A batteries.
    • If applicable, pull on the black ribbon to release all six Triple A batteries at the same time.
    • Be careful not to damage any of the spring terminals when removing the batteries.
Conclusión
To reassemble your device, follow these instructions in reverse order. If applicable, make sure to set the black ribbon first for future disassembly.
Mike Dam
Miembro Desde 09/25/14
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 5-2, Mcgee Fall 2014 Miembro de USF Tampa, Team 5-2, Mcgee Fall 2014
USFT-MCGEE-F14S5G2
Miembros de 4
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,364
