Saltar al contenido principal
DROCON Ninja Casing Replacement
Qué necesitas
  1. DROCON Ninja Casing Replacement, Battery: paso 1, imagen 1 de 3 DROCON Ninja Casing Replacement, Battery: paso 1, imagen 2 de 3 DROCON Ninja Casing Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
  2. DROCON Ninja Casing Replacement, Casing: paso 2, imagen 1 de 3 DROCON Ninja Casing Replacement, Casing: paso 2, imagen 2 de 3 DROCON Ninja Casing Replacement, Casing: paso 2, imagen 3 de 3
    • Using a Phillips #00 Screwdriver remove the eight 4mm screws on the bottom of the drone.
  3. DROCON Ninja Casing Replacement: paso 3, imagen 1 de 2 DROCON Ninja Casing Replacement: paso 3, imagen 2 de 2
    • Gently pull white casing away from the black bottom casing
  4. DROCON Ninja Casing Replacement: paso 4, imagen 1 de 3 DROCON Ninja Casing Replacement: paso 4, imagen 2 de 3 DROCON Ninja Casing Replacement: paso 4, imagen 3 de 3
    • Insert the opening tool under one of the black plastic connector slots that connects the circuit-board to the casing.
    • Gently pull the opening tool toward you to disconnect the circuit-board from the plastic casing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 11
Todo El Tiempo: 137
