Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
  1. Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body. Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • Use the JIS #00 screwdriver to remove the 3/32" screws that secure the speaker to the body.
    • Remove the smaller 3/32" screws that secure the left side of the speaker with a JIS #1 screwdriver.
    • The smaller screws are still the same length, but they have smaller screw heads. You can use the same screwdriver for both.
    • Using a Magnetic Mat throughout this process will help prevent losing screws.
  2. Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires. Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
    • Use the Plastic Opening Tool to gently lift the speaker enough to see the connected wires.
  3. Use a soldering iron to de-solder the two speaker wires from the speaker itself. The speakers are ready to be removed and replaced.
    • Use a soldering iron to de-solder the two speaker wires from the speaker itself.
    • The speakers are ready to be removed and replaced.
    • Ensure that the device is turned off when handling bare wire.
    • Soldering iron is very hot.
Conclusión
To reassemble your device, follow instructions in reverse order.
Una persona más ha completado esta guía.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 45
Todo El Tiempo: 1,329
