Saltar al contenido principal
DOSS SoundBox Base-plate Removal Replacement
Qué necesitas
  1. DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: paso 1, imagen 1 de 3 DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: paso 1, imagen 2 de 3 DOSS SoundBox Base-plate Removal Replacement, Base-plate Removal: paso 1, imagen 3 de 3
    • Locate the four 3/32" screws on the bottom of your device.
    • Using a JIS #00 screwdriver, remove the four 3/32" screws.
    • After removing the screws, lift the cover off of the device.
  2. DOSS SoundBox Base-plate Removal Replacement: paso 2, imagen 1 de 1
    • Using a JIS #1 screwdriver, remove the six 3/32" screws that attach the base-plate to the speaker enclosure. These screws are marked with red circles.
    • Using a JIS #000 screwdriver, remove the two 1/16" screws from the areas marked with an orange circle.
    • Having the magnetic pad handy will be beneficial, as these screws are very small and easily lost.
  3. DOSS SoundBox Base-plate Removal Replacement: paso 3, imagen 1 de 1
    • Lift the base-plate off of the enclosure.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 1,972
