Saltar al contenido principal
DOPO 10.1 Tablet Speaker Replacement
Qué necesitas
  1. DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: paso 1, imagen 1 de 3 DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: paso 1, imagen 2 de 3 DOPO 10.1 Tablet Speaker Replacement, Separating the Covers: paso 1, imagen 3 de 3
    • • Insert tool into crease between covers. First, insert one of the plastic tools between the front and back cover as shown. Next, twist the plastic tool until separation has occurred between the front and back of the tablet. Repeat this step until the user is able to fully separate the front and back covers.
  2. DOPO 10.1 Tablet Speaker Replacement, Locate the Speakers: paso 2, imagen 1 de 2 DOPO 10.1 Tablet Speaker Replacement, Locate the Speakers: paso 2, imagen 2 de 2
    • The speakers should be attached to the white cover of the tablet as shown. Follow the wires back to the mother board making sure to remove all tape attaching wires to cover along the way. This will free up the wires for easy maneuverability.
  3. DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: paso 3, imagen 1 de 3 DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: paso 3, imagen 2 de 3 DOPO 10.1 Tablet Speaker Replacement, Clearing the Pathway to Remove Speakers: paso 3, imagen 3 de 3
    • We will need to separate the battery from the panel slightly. This will allow for easier maneuverability to remove speakers. Do not separate the battery completely.
  4. DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: paso 4, imagen 1 de 3 DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: paso 4, imagen 2 de 3 DOPO 10.1 Tablet Speaker Replacement, Desoldering Speakers from Tablet Motherboard: paso 4, imagen 3 de 3
    • De-solder the red and black wires from the tablets motherboard. This will officially disconnect, and separate the defective speakers from the motherboard.
  5. DOPO 10.1 Tablet Speaker Replacement, Removing Speakers: paso 5, imagen 1 de 1
    • Remove defective speakers from their location in tablet.
Conclusión
Kaitlyn Hayes
Miembro Desde 01/21/15
414 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 5-2, Brown Winter 2015 Miembro de USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 872
