Saltar al contenido principal
DOPO 10.1 Tablet Screen Replacement
Qué necesitas
  1. DOPO 10.1 Tablet Screen Replacement, Screen: paso 1, imagen 1 de 3 DOPO 10.1 Tablet Screen Replacement, Screen: paso 1, imagen 2 de 3 DOPO 10.1 Tablet Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove back case of tablet by taking spudger tool to lift the back plate.
  2. DOPO 10.1 Tablet Screen Replacement: paso 2, imagen 1 de 2 DOPO 10.1 Tablet Screen Replacement: paso 2, imagen 2 de 2
    • With caution, unplug speakers from back case of tablet.
  3. DOPO 10.1 Tablet Screen Replacement: paso 3, imagen 1 de 2 DOPO 10.1 Tablet Screen Replacement: paso 3, imagen 2 de 2
    • Remove battery
    • Grab and apply light pressure to battery to release it from the back
    • Place off to the side carefully. Be sure not to disconnect cables from motherboard
  4. DOPO 10.1 Tablet Screen Replacement: paso 4, imagen 1 de 3 DOPO 10.1 Tablet Screen Replacement: paso 4, imagen 2 de 3 DOPO 10.1 Tablet Screen Replacement: paso 4, imagen 3 de 3
    • Locate where the cameras are attached to motherboard
    • Now release and remove them from motherboard
    • Take camera out and place off to side
  5. DOPO 10.1 Tablet Screen Replacement: paso 5, imagen 1 de 3 DOPO 10.1 Tablet Screen Replacement: paso 5, imagen 2 de 3 DOPO 10.1 Tablet Screen Replacement: paso 5, imagen 3 de 3
    • Remove motherboard
    • To do this you will have to unscrew a total of 5 .25in phillips head screws
  6. DOPO 10.1 Tablet Screen Replacement: paso 6, imagen 1 de 3 DOPO 10.1 Tablet Screen Replacement: paso 6, imagen 2 de 3 DOPO 10.1 Tablet Screen Replacement: paso 6, imagen 3 de 3
    • Remove back metal piece.
    • Use plastic pry tool and go around the edges lightly and pop it off.
  7. DOPO 10.1 Tablet Screen Replacement: paso 7, imagen 1 de 3 DOPO 10.1 Tablet Screen Replacement: paso 7, imagen 2 de 3 DOPO 10.1 Tablet Screen Replacement: paso 7, imagen 3 de 3
    • Using a plastic opening tool, remove the back screen pieces from the back.
  8. DOPO 10.1 Tablet Screen Replacement: paso 8, imagen 1 de 2 DOPO 10.1 Tablet Screen Replacement: paso 8, imagen 2 de 2
    • Using the plastic pry tool remove metal frame.
  9. DOPO 10.1 Tablet Screen Replacement: paso 9, imagen 1 de 1
    • Take the iFixit iOpener and place it on the glue
    • This will release the glass from the plastic frame
  10. DOPO 10.1 Tablet Screen Replacement: paso 10, imagen 1 de 1
    • Carefully remove glass. If glass is already broken use gloves to remove glass.
Conclusión
Michael
Miembro Desde 01/21/15
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 5-2, Brown Winter 2015 Miembro de USF Tampa, Team 5-2, Brown Winter 2015
USFT-BROWN-W15S5G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 1,656
